Power supply
iramesor
7
my power supply of my dell inspiron 530 failed and I changed fora new one, after working fine for 2 weeks the new ps failed; any ideas what is causing this? thanks
Hi
It was shark technology
Connector Summary
1x 24pin Main Power Connector,
1x P4 4pin Power Connector,
1x Floppy Drive Power Connector.
3x SATA Power Connectors (on 2 seperate line of cables to reach drives located in various part of the case)
4x Peripheral Power Connectors for IDE drives or case fans.
Complies with INTEL® ATX 12V standard
Super Silence Technology provides best solution for fan noise and heat
High efficiency output
One 12VDC 120mm low-RPM fan
Output short circuit protection (except +5VSB)
Output over voltage protection
Output over wattage protection (620W)
Manual power shut down rocker switch
I am just wondering if the motherboard has diabled the new power supply?
Many thanks
Can be but it is a low quality PSU that could have died by itself. Quality PSU's have internal protection so they will not turn on for example if there is a motherboard short.
any suggestions for better psu?
many thanks
