Power supply
TheMaverick
146
When I overclock my CPU my computer wont restart when I tell it to could this be because of a lack of power? Should I upgrade to a 400W Powersupply?
AMD XP 1900+
A7V-333
Geforce 3 TI 200
PC2100 512MB
What do you mean by "won't start"? How did you overclock (clock multiplier/FSB)? What did you try to clock to? Try to be very specific.
Its normal that your CPU won't restart if you overclock too far. Try lowering your FSB and/or multiplier, it should probably post then. If you'd give more detailed specs it would help though.
"If there's grass on the field...play ball!!"
Or perhaps increase your core voltage...but make sure you have some good cooling on your cpu.
