So, I know there are probably tons of posts out there similar to this one.. but I have tried everything and I need some advice.
I had a power surge a couple days ago, it happened twice about 2 seconds apart while I was on my computer. When it came back, my pc was all powered up every light came on, every fan (gpu, power supply, cpu, case fans), but NO DISPLAY. Also, I was plugged into a power surge protector.. do they even work?
My first move was to restart.. everything came on the same way, still no display. So, my first hope was the monitor/hdmi cable was fried so I plugged in my laptop and it was fine.
I let it sit overnight unplugged, still didn’t work. Tried different slots on my power supply for different things. I switched the RAM around, I reset CMOS, everything.
Today, I went and bought a power supply from Best Buy and tested that out.. still nothing so it’s not the power supply.
After trying that, I threw in my old mobo with my old cpu and ram. And it booted up just like usual, with a display.
Now, I believe I am left with the options of CPU and/or mobo being bad. What should I do?
Is there any cosmetic damage that would occur to my cpu that I could easily rule it to be fried? My motherboard looks okay, the case fans get power from that and they booted just fine so could it still be the mobo? I’d rather have it be the mobo since it’s cheaper.
Thanks!
Colin
Specs:
Gigabyte AB350M-gaming 3
Ryzen 3 1300x
EVGA 1060 3gb ACX 2.0 SC
G.Skill ripjaws v 8gb
PSU during power surge: SeaSonic M12II EVO 520w
PSU now: EVGA 600W
Thanks!
Colin
Specs:
Ryzen 3 1300x
PSU now: EVGA 600W
