Power surge pc restarts
according to this thread, it was the guy's house wiring at fault causing this
http://www.tomshardware.com/answers/id-1773912/asus-anti-surge-problems.html
you can get a cheap thing to plug into the plug where the pc is getting power to test if it has circuit problems as the solution in that thread points to.
get one of these and test your plugs
https://www.amazon.com/Sperry-Instruments-GFI6302-Receptacle-Professional/dp/B000RUL2UU/ref=sr_1_4?s=lamps-light&ie=UTF8&qid=1538155096&sr=1-4&keywords=circuit+tester
if errors detected, don't use that to power your pc, get an electrician to fix the house wiring.
