Hello guys.I have my tower on my top shelf almost 1.5 meters away from me. I wanted to have a power button next to me so i don't have to stand up and reach the cases button. I bought a button from ebay and i used 1meter cable + an old cases' "power sw cable" and I connected them to my pc. My issue is that it worked only once and then my pc couldn't turn on even with the standard button (i tried connecting it with my keys or even a screwdriver but still wouldn't turn on).I thought that maybe the cables length was the problem and was draining all the power from the motherboard (MAYBE) so i disconnected the psu from the mobo and reconnected it and then it worked. The standard case button works just fine but if i connect the extended one it happens again.What should i consider the possible causes? If you have some advises of what kind of cable should i choose or whats the max length of the cable i can use i would appreciate it.
CPU; i7 7700k no overclocked
GPU; gtx 1080 g1 gaming
3x140 rgb fans
corsair H45 watercooler
MOTHERBOARD; MSI Z270 A-PRO
PSU; thermaltake 750w gold
3x140 rgb fans
