Power Switch Stuck [ Help Please ]
sonkirito
On the back of my desktop I flicked my power switch and than moved my pc when i got it home i notice that it was stuck and it won't flick back to the other side and now i can't turn it on can you please tell me how to turn it on OR fix this i don't care if the switch is still broken or if it even is broken I just want to be able to turn it on so pls help
By the way this isn't the button that turns it on at the front its the power switch at the back
and my power supply is RK-P650 ATK-12V 2.3 VER.
u can using flat & thin screw driver and insert it on gap in the flip switch, and gently try flip it back..
no need open up the psu, but again it still have risk... (safety first)
and it better supervised/ask people helps if u not confident..
rdc85
u may need use force and tools.. (flat skrew driver) to flip it back..
but before that make sure it not connected with any electricity. since risk of electrocuted/fire is there..
(always keep safety measure first)
sonkirito
@Slobodan-888 You don't give a lot of help do you? I don't see how Im messing with dangerous power supplies Just because Im not an expert doesn't mean I'm an idiot! All I asked for was help to get my computer to start or switch to work.
rdc85
