Question Power switch
Apr 25, 2019
4
That sounds silly but when I use the screwdriver it works but not when I use the power switch and I tried to plug it everywhere on the front panel
Apr 25, 2019
4
Joakim Agren
Proper
Sep 5, 2019
142
20
115
7
Try switching the power switch connector with the reset button connector and see if it works to power on the PC when you push the reset button instead. If this is the case it means your power switch cable or the actual power button on the case is broken. If so you might need to get a new front panel I/O replacement from your case manufacturer.
