Power/Watt Usage Monitor
radium02
54
Is there a device which I can plug into the wall and than plug my power cable from my power supply into so that I can get a reading of how many watts and amps my computer is drawing from the wall?
I think I've seen something like this before but not sure what it may be called or where I can purchase it.
Thanks in advance.
That's good! Thanks for the link badge.
Is there a way I can calculate the amount of power (in Watts) that a component is using simply by knowing the amount of volts it requires?
(P = V x I).
The easiest way to do that would be to use a DC clamp ammeter. This, along with a unit like the kill a watt, allow you to see total and component power consumption. It's what I use.
P = V x A
You need to multiply volts times amps to get the total wattage.
The volts is usually the first thing mentioned on a label on a device, the amp rating is sometimes missing.
You could just use what joefriday said to get the actual reading.
