PowerA PS3 Pro Elite Wireless Controller to PC?
Muzammil Seyed
25
So I have this PowerA PS3 Pro Elite Wireless Controller -
CONTROLLER - http://www.newegg.com/Product/Product.aspx?Item=N82E16879815016
Is there anyway i can connect this to my PC?
I tried connecting it with the USB Cable the Controller lights up but it doesn't show anything on my PC
I did search for the drivers There are no Drivers of that controller for PC
I installed MotioninJoy and tried connecting it MotioninJoy Doesn't show any controller
Is There anyway i can connect this controller too my PC? Please HELP.
ok so i found out how to make it work so get the Hackedgamepad by sarathgamer open it up and then plug in the usb and make sure it works properly which it should do automaticly or you can manually do now go to options check all of the xinput boxes then go back to the main controller where you made sure you had the gamepad working right click save and now go into the hacked gamepad folder and copy everything exept the hacked gampad by serathgamer aplication and past the other things into the folder that holds the games launcher and if it was done right when you start up your game it should make a noise when it starts up thats how you know it worked but it doesnt work for every game but does work for alot of them
If no one has a driver, then the only solution is to write your own driver.:ange::ouch::??:
Or get a controller that DOES have drivers available.
i have a similar problem i have been told to try this http://www.digitaltrends.com/computing/how-to-connect-a-ps3-controller-to-a-pc/ but i myself have not been able to get it to work maybe you can
