So I just recently built a new build and this is the first time I have ever used AMD hardware. I went with the Power Color Red Devil 5700XT for the GPU and it works just fine (with a few caveats). My problem is that in order to see the GPU temp, I have to go through the Power Color RGB controller. Every other hardware monitor either doesn't show an the Temps or will display NaN (or something like that).
Has anyone else had this issue? and if so, is there a way to fix it so that I can monitor temps through CPUID or something similar?
P.S. It shows everything else like GPU usage and memory usage, just not temps.
