I recently purchased a PC from iBUYPOWER with the following info
Asrock H81M-HDS Motherboard
Intel Core i5-4690K 3.5 GHz
8 GB DDR3 1600
400W PSU
Windows 8.1 64-Bit
AMD Radeon R7 250x 1GB
I've been through the ringer trying to get this thing to work. I can only get the display to work through the onboard graphics with the onboard as the primary. If I set the PCI-e as the primary, I get no display at all from either. Even using the onboard with the card installed, the system freezes on every restart. It only runs perfectly when the graphics card is completely removed. When I try to install drivers, the system freezes (this is after using Display Driver Uninstaller). If I try to install drivers in Safe Mode, I get a "Failed to load detection driver" error. I've tried new drivers and old drivers. I've re-installed Windows twice.
I've successfully installed the 14.12 driver once (I have no idea why it worked that one time). After switching the PCIe back to primary and plugging the output into the card, I still got no picture.
I'm at a loss at this point. I'm still cycling through drivers hoping one of them is the answer. Can it be the card was DOA? How can I be sure without a second machine to test it in?
Thanks for any help. If you need any more info I'm sure I can find it. I'm about ready to ship the darn thing off and start over.
8 GB DDR3 1600
400W PSU
Windows 8.1 64-Bit
