PowerColor Radeon HD 7870 XT problem?
Trong Dinh
45
So i heard that the PowerColor Radeon HD 7870 XT has some heating problem.. Does anyone have a solution to this or is there a card that you would prefer me to buy.. Thank you very much
This is the build that imma do.. please give me some feed back
CPU: AMD FX-8320 3.5GHz 8-Core Processor ($149.99 @ Microcenter)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($29.98 @ OutletPC)
Motherboard: ASRock 970 EXTREME4 ATX AM3+ Motherboard ($99.99 @ Newegg)
Memory: G.Skill Sniper 8GB (2 x 4GB) DDR3-1600 Memory ($79.99 @ Newegg)
Storage: Kingston SSDNow V300 Series 120GB 2.5" Solid State Disk ($89.98 @ OutletPC)
Video Card: PowerColor Radeon HD 7870 XT 2GB Video Card ($139.99 @ Newegg)
Case: Thermaltake Commander MS/I Snow Edition (White/Black) ATX Mid Tower Case ($37.99 @ Microcenter)
Power Supply: Corsair CX 600W 80 PLUS Bronze Certified ATX12V Power Supply ($54.99 @ Microcenter)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer ($16.98 @ OutletPC)
Total: $685.88
(Generated by PCPartPicker 2013-11-06 22:14 EST-0500)0 |
Well most of the time you'd have to manually paste things to the HDD, or setting downloads to a folder within the directory of the HDD. When install programs you don't really use often you can just use custom install and direct it to the HDD as well.
You could just stick with Windows 7 64 bit for now and upgrade to Windows 8 or 9 (when it comes out) when the need arises in the future
Hey there again, why did you remove the 1tb storage drive? it's worth getting a storage drive for all your other programs and games etc.
It would be good to have a storage drive so you can move your page file there without using up the read/writes of the SSD too much
(The G.Skill Ripjaws ram was also cheaper than the G.Skill Sniper listed above)
Adding a few case fans for better airflow definitely helps, anything below 85 degrees celcius for a video card is safe
Here's a video about the card
http://www.youtube.com/watch?v=BTVmwsGcE-8
Hello!
I actually bough that Memory 3 weeks ago already 🙁
I feel like i should just put everything in the SSD so it would open faster 😛
Ohh no wonder haha, it's generally recommended to have Windows, a few important applications, a few games on the SSD and have everything else on a normal HDD
Things like video files, mp3 files and all that stuff should be stuffed onto the HDD as you'd see no real benefit leaving them on the SSD
:3 maybe i should have post and met u before i buy the memory >.<
let say if I get both SSD and HDD
do i have to manually copy and paste thing to HDD or is there a way that i can set up for certain things to be put on SSD and HDD
One more thing im puzzling on what OS i should get window 8 look so complicated and scary
