Powerful Mini ATX - Micro ATX build
Cromat88
133
I have to put together a gaming pc for a client. The client will only settle for top of the range and isn't interested in a gaming laptop. He goes to tons of LAN's hence the reason for the form factor so he can literally just carry the box under the arm and the screen in the other hand. So he basically wants the best available components in a tiny box i wanted him to at least get a ATX build but he wouldn't budge. Only want a Micro or Mini ATX build. So guys any input will be appreciated.
Approximate Purchase Date: End of this month or next month
Budget Range: N/A (money is no object)
System Usage from Most to Least Important: Gaming,Music,Movies
Parts Not Required: Need Everything
Preferred Website(s) for Parts: I deal directly with suppliers so no internet sites are required
Country: South Africa
Parts Preferences: I can only get the following brands from my suppliers, MSI, GIGABYTE, COUGAR, RAIDMAX,CORSAIR, SEAGATE, WESTERN DIGITAL, SAMSUNG (SCREENS) PROLINE, RAPTOR, THERMALTAKE, LOGITECH, INTEL (Client doesn't want AMD)
Overclocking: No
SLI or Crossfire: No
Monitor Resolution: 1920x1080
Additional Comments: As small,quite and powerful as possible.
I think your best bet would be to grab something like this:
i5-3570K
8GB Corsair 1600Mhz RAM
MSI/Gigabyte Mini ITX Z77 motherboard
240GB Intel 520 Series SSD
HD 7850 (Sapphire/ASUS if possible but there is a Gigabyte one)
Samsung Bluray Burner
Scythe Shuriken CPU Cooler (If you have to go with Thermaltake you could grab the Thermaltake Slim X3 CLP0534 and put a quieter fan on it.)
For the case and PSU I would personally avoid Thermaltake for a 'money is no object' build. I would try to source the Seasonic X-560 and the LIAN LI PC-TU200.
Now you could probably fit a more powerful graphics card in there but I wouldn't recommend it to be honest. The HD 7850 is small enough to fit in that case and should run cool and quiet. You may be able to cram a GTX 680 or something in there but it might get noisy.
Total cost on Newegg is around $1500 so maybe 12,000-15,000 ZAR
I hope this helps.
Cromat88
133
Thanks JM that build looks good ill forward the info to the client and ill see what his response is i had something similiar in mind but a 570GTX as a card. Iam just trying to get as much input from the community as possible before i start ordering and putting the PC together
It probably revolves around your case selection.
I think it's great than we can build ITX but your chums best bet is probably mATX simply for practicality. It's not going to be than much bigger than ITX, anyway. TT has some 'cube' cases that may be available to you that might take 10-inch cards. A SilverStone SUGO would be great if available to you. They will take quite a large card -- probably anything you throw at it.
An mATX board should add more fan & other headers, access to PCIe and PCI slots, and more room for a 2-slot card video card.
And that's what it comes down to . . . your video card. A Radeon HD7850 and Ivy Bridge is a great choice, but a guy (or girl) with a Radeon HD7970 and a PhII 965 will get better frames in almost all cases. Remember: It's the video card.
As far as Ivy, early reports seem to suggest it might run a touch warm compared to Sandy, though with less power, which is not really a priority, here (except for too much heat).
As far as quiet -- with an mATX chassis with a second external 5.25-bay, you may add an appropriate fan controller. Aggressive speed control through hardware and software is the ticket, here, so you should probably select the OEM-brand motherboard with which you have had the best success.
I think Ivy Bridge should be cooler than Sandy at stock, it's overclocking where it gets hot as far as I'm aware.
The reason I suggested that Lian Li case was because it looks great, it has that carrying handle and it's very light so he could carry it in one hand. If you can find a mATX tower with those things, that would be even better. I struggled to find one myself
http://www.newegg.com/Product/Product.aspx?Item=N82E16811112347
Cromat88
133
Thanks for the reply's guys the client looked at the build suggestion and said he will settle for a Micro-ATX build he said as long as he can carry it one handed he doesn't have a problem. We went over the specs and this is the final build i put together. I got an email saying he wants the build by Wednesday next week and my supplier is only getting the Ivy Bridge CPU's 1-2 months from now (the joy of living in south Africa :( ) just remember i can only get certain brands and/or parts from my supplier and this is the best i could come up with. I did a lot of measurements and this should technically work any input would be appreciated. Also he said noise wouldnt be to much of a problem as long as its powerful. He is also going to do some custom mods to the case as well to improve airflow at a later stage.
GPU: http://www.gigabyte.co.za/products/product-page.aspx?pid=4102#sp (i have done the measurements this graphics card will fit in the case listed below since the case doesnt have a HDD bay which goes all the way to the bottom of the case)
CPU: http://ark.intel.com/products/52210
CASE: http://www.gigabyte.co.za/products/product-page.aspx?pid=2482#sp
MOBO: http://www.gigabyte.co.za/products/product-page.aspx?pid=4143#sp
RAM: http://www.corsair.com/vengeance-8gb-dual-channel-ddr3-memory-kit-cmz8gx3m2a1866c9.html
PSU: http://www.corsair.com/power-supply-units/gaming-series-power-supply-units/gaming-series-gs500-80-plus-certified-high-performance-gaming-500w-power-supply-unit.html
SSD: http://www.corsair.com/ssd/force-series-gt-ssd/force-series-gt-480gb-sata-3-6gbps-solid-state-hard-drive.html
HDD: Western Digital Caviar Black 2TB
SCREEN: http://www.samsung.com/africa_en/consumer/pc-peripherals-printer/monitors/led/LS23B550VS/XA
MOUSE: http://www.logitech.com/en-za/mice-pointers/mice/devices/5092
KEYBOARD: http://www.logitech.com/en-za/keyboards/keyboard/devices/4956
FANS: 3x Thermaltake Standard 92mm fan (1 in front blowing in, 1 at the back blowing out and 1 on the side blowing in)
CPU COOLER: http://www.thermaltakeusa.com/Product.aspx?C=1417&ID=1905 (this is the best cpu cooler i could get considering case size)
Thanks again guys just remember this is the best i could put together considering what my suppliers can get. Any input would be appreciated
Agreed .
The gigabyte case is way too cheap and poorly ventilated .
Cromat88
133
Unfortunately i don't have any other options and some of the other brands i can order are even worse quality. Just remember i can only get certain brands or parts from my suppliers. Your forgetting i live in South Africa and don't have the thousands of options that the US or EU have. But he said the case will be modified at some later stage to improve ventilation.
Dovetonsils
9
It will work out great for your mate -- hopefully heat-ventilation, noise, etc . simply are not as issue. Under-volt the CPU and Power-Tune the Radeon a bit. Problem solved.
It's really annoying with the 90/92mm fan thing. It's just simply annoying. Did I mention it's annoying?
Maybe you can fashion some small rubber spacers (nails used for metal roofing have them) and 'skew' the screws in without too much hassle.
That's custom-engineered sound optimizations for quiet operation where I live :D
Tavo_Nova
1,159
38
well you can grab a matx mobo and if the fans are still too small just punch some holes in it and add a 140 or something ^_^
silverstone got awesome fans but seems you can't grab some.
go with matx with a thermaltake case
Cromat88
133
Well okay whats done is done. Ive assembled the PC and tempretures are reasonable inside the Gigabyte case. I ran MSI Kombuster and these are the highest recorded temps. Take note: It is quite cold this side of the world so that could be contributing to the temps.
CPU IDLE: 36c
CPU LOAD: 49c
GPU IDLE: 45c
GPU LOAD: 83c
The client said hes going to get someone to modify the side panel and add a 200mm intake fan and then modify the top of the case to add a 120mm exhaust fan so overall this addition should drop the temps even more
Similar threads
