Powering a 4 pin fan controller with any cable?
Fonzie_1
Now I have recently bout a deep cool fan controller, http://www.newegg.com/Product/Product.aspx?Item=11-990-008
Now in the box it comes with a 4 pin Molex power cable that that adapts to a 4 pin connector just like the ones on a fan to give the controller power. Now my motherboard is a Asus M5A99FX Pro R2.0 which doesn't have any slots for a 4 pin Molex power cable. My question is could I just use a 4pin fan extension cable to give it power or should I find an expansion card that would support it, or if there's another way to connect it.
Thank you in advance.
