Powering a CPU fan from 5v USB power?
Cant imagine how would you manage to put it into the laptop, noneless you will have to make some adapter molex-> usb or pin3/4 -> usb. Other thing is that 5v from usb... even it should be enough to start it spinning the efficiency will be minor. You wont need any resistor... the oposite you would like to have a converter from 5->12V to get it working better... but that's not really brightest way to achieve the effect.
