I read an article and some posts on different forums that the way to fill a loop with the coolant is to disconnect everything from the power supply except for the water pump and the 24-pin ATX cable. I have a bridge connector to plug into the 24-pin ATX cable that will jump pins 15 and 16. So, then I use the power supplys switch to turn on/off the water pump. But, what I do not get is... where is the water pump connected to? If everything else is disconnected from power, then how does the water pump get power?
