Powerline Adapters Not Connecting My PC
RobotLizard
124
Im trying to set up a powerline network for my new PC, using the Zyxel PLA4211 adapters.
I followed the install instructions, plug one into the router, and one into the PC.
Both adapters show a green power light and a green light that signals they are connecting to ethernet ports, but my computer isnt connecting to the internet.
Can anyone help?
Is the HomePlug light on (light with house/plug symbol)? If not, the adapters are not communicating with each other.
First test the adapters on outlets that are close to each other (on the same circuit). The HomePlug lights should show a connection.
Make sure the adapters are not plugged in to power strips or surge protectors. They must be plugged directly into the wall outlet.
The adapters may not work if they are placed on outlets fed by an opposing circuit breaker.
