Powerline networking solution
Yes, those are fine, and are the latest AV500 standard. You can add a 3rd powerline adapter, you just need to set them all to the same encryption key. This is done via included software, or plugging the adapter in and pressing a button, depending on the model.
Just also remember to plug them directly into the wall, and not a surge strip.
Also realize that you can get the powerline adapters with a WiFi access point built in for a little more, so plan out your network before you commit to the purchase.
http://www.amazon.com/TP-LINK-TL-WPA4220KIT-ADVANCED-Universal-Powerline/dp/B00HSQAIQU/ref=sr_1_1?ie=UTF8&qid=1408119128&sr=8-1&keywords=powerline+wifi
