Powersupply Suggestions for my build
Avocade
1,002
I need a PSU for around $90ish thats at-least 750W.
Needs 4 8 Pin PCI-E Connectors or 4 6+2.
i7 4770k
8 GB Corsair Vengence 1600Mhz Ram
GTX 780 Classified (this will be SLI'd in the future.)
Gigabyte GA-Z87X-HD3
It needs to be through amazon.
I'm not good with selecting quality PSU's
There are plenty of good choices for 750W in the $90 range. If you want to purchase one on amazon just do a quick search and toggle the filters for 80+ certified and 700-799W. Then you just want to pick one that is bronze certified or better and a good brand name. You can read through customer reviews also. Mainly though, just pick the one for the best price and appeals to you.
If you are planning on using SLI 780's in the future, I would recommend getting a higher power supply at around 800W or higher.
http://www.amazon.com/s/ref=sr_nr_p_n_feature_keywords_1?rh=n%3A172282%2Cn%3A541966%2Cn%3A193870011%2Cn%3A1161760%2Ck%3Apsu%2Cp_n_feature_keywords_two_browse-bin%3A6906986011%2Cp_n_feature_keywords_browse-bin%3A2888266011&keywords=psu&ie=UTF8&qid=1396995200&rnid=2888248011
