As the title says i have a pre built pc that i would like to upgrade with new parts. Below is my current PC. I am from the UK.
Current PC
CPU: AMD FX 4300(it is really old haha)
Gpu: Nvidia GTX 960 2GB
RAM: 8GB
Morther Board: MSI 760G-P23(FX) MS-7641
Fans 3, one on the back, side and front. Also have a standard CPU fan that comes with it.
Upgrade Parts
CPU: AMD Ryzen 3700X
GPU: AMD card equal to the rtx 3080?
RAM: Corsair Vengance LPx DDR4 3200 MHz 2x16 C16 XMP High performace
Mortherboard: MSI MAG B550M Mortar wifi micro atx am4
SSD: Samsung 860 EVO 1TB
I need more help with the technical stuff. I need advice on what motherboard to buy? what fans and power supply to buy? Is there and AMD graphics card that is equal to the GTX 3080? Perhaps i can get a cheaper Wifi Board? or go with a 3060 ti instead of the 3080? The Ryzen 7 only does up to 3200 MHz on ram speed. Any advice would be great.
Current PC
RAM: 8GB
Upgrade Parts
