Question pre build Technical question
May 11, 2020
Hi everyone-
I’m doing a build on a MPG X570 GAMING EDGE WIFI motherboard with a Lian LI COOL II case (ARGB). The issue is that I have bunch of Fans / ARGB’s to hook up and I just want to make sure I should use the “MasterFan ARGB AND PWM HUB” so that I can run everything and not have any issues with the motherboard. (I already know this board runs hot, hence my effort on the extra fans) *best MB I could find / afford right now :p
Fans / ARGB’s listed below:
  • Front (pull): MasterFan MF120R ARGB 3in1 (1 = ARGB required)
  • Front (push): 3 X 120mm case fans 12V 0.21A (1300 RPM) (3 X SYS_Fan required)
  • Case top and back: MasterLiquid ML360R RGB (1 = ARGB required)
  • Case LED requires (1 = ARGB required)
MPG X570 GAMING EDGE WIFI motherboard (Internal Connectors)
  • 1x 24-pin ATX main power connector
  • 1x 8-pin ATX 12V power connector
  • 1x 4-pin ATX 12V power connector
  • 6x SATA 6Gb/s connectors
  • 2x USB 2.0 connectors (supports additional 4 USB 2.0
ports)
- 2x USB 3.2 Gen1 connectors (supports additional 4 USB 3.2
Gen1 ports)
  • 1x 4-pin CPU fan connector
  • 1x 4-pin water-pump connector
  • 4x 4-pin system fan connectors
  • 1x Front panel audio connector
  • 2x System panel connectors
  • 1x TPM module connector
  • 1x Serial port connector
  • 1x Clear CMOS jumper
  • 1x Chassis Intrusion connector
  • 2x 4-pin RGB LED connectors
  • 2x 3-pin RAINBOW LED connectors
  • 4x EZ Debug LEDs
Any advice on the wiring / confirmation that the MasterFan ARGB AND PWM HUB should be used would be appreciated.
Other components here: https://pcpartpicker.com/list/JWjkPn
Thanks for the help,
JW
