Pre-built PC Build
JT94
Hey guys, I'm just about to purchase my first gaming pc and don't fancy learning to build one at this early stage so I've picked out this PC:
https://www.gladiatorpc.co.uk/configure/config/62033
My question is will it be able to run the games I want to play on high to mas settings with consistent 30-60 fps?
I want to run:
Battlefield4
Arma 3
Planetside 2 & H1Z1
DOTA 2
Dayz
The Forest
& Days to die
If someone knows of a better PC for around the £800 mark that comes pre-built that would also be helpful.
CPU Intel Core i5-4670K 3.4GHz Quad-Core £166.74
CPU Cooler Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing £25.44
Motherboard Asus Z97M-PLUS Micro ATX LGA1150 £102.08
Memory G.Skill Ripjaws Series 8GB (2 x 4GB) DDR3-1600 £55.80
Storage Kingston SSDNow V300 Series 60GB 2.5" SSD £32.90
Seagate Barracuda 1TB 3.5" 7200RPM £35.94
Video Card Zotac GeForce GTX 970 4GB £255.59
Case Fractal Design Define Mini MicroATX Mini Tower £56.98
Power Supply Corsair 500W ATX12V £49.60
Optical Drive Samsung SH-224DB/BEBE DVD/CD Writer £10.46
http://uk.pcpartpicker.com/user/enderstream/saved/B9sscf
Total: £791.53
Stores would build this for a fair price
you could build a PC TWICE as better for the price, And if you are not familiar with building, Computer shops will do it for you for pretty cheap.
Anyway it will run those games, The 280X is a great card
For the same price, You could order a built PC with a GTX 980 And get 30% more fps
Its good, Although i would be worried still about the 2GB vram, games will utilize more, And he wont be able to play demanding games using MSAA Without bunking at the 2GB
800 pounds with gtx 980? lol, where did you come from?
970 Sorry.
Although this one as Demosthenest has added is quite good, If you dont wish to get a custom one built, I would go with that:http://www.chillblast.com/Chillblast-Fusion-Sniper-Elite-Z97-Haswell-Gaming-PC.html
Total: £791.53
