If there is no hub on the case that also needs to be connected to one of the fan headers on the motherboard, then you probably need to connect those fans directly to the motherboard fan headers. Honestly, I'm not too sure with these RGB fans and controllers, but if the motherboard has an integrated RGB controller, you might try connecting to that. Likely, the case manual will tell you where those need to be connected and unless I'm way off my mark, there are usually connectors for both the RGB AND the fan controls, and both need to be connected, so you need to chase down the end of the cable and make sure that both the RGB and 3 or 4 pin fan control connectors are attached where they belong.
