A Aradim Honorable Jan 30, 2014 25 0 10,540 Feb 17, 2016 #1 I've never dealt with a fully cabled PSU and cable management, I've read horror stories here about people causing a short circuit and burning their board and CPU, what measures should I take to avoid any incidents?
Solution B B Bryan87 Feb 17, 2016 You can buy an anti static wrist strap for under $5. I use it all the time. Plus touching metal for a ground often, not being on carpet which causes friction are all good practice. http://www.amazon.com/BestNow-Static-Eliminator-Elastic-Wristband/dp/B00ZI187I8/ref=sr_1_1?ie=UTF8&qid=1455701696&sr=8-1&keywords=anti+static+wrist+strap+wireless
Mr Kagouris Judicious Sep 7, 2015 3,966 2 32,565 Feb 17, 2016 #2 Plug in everything correctly? You don't need any special precautions. Upvote 0 Downvote
B Bryan87 Honorable Nov 30, 2013 15 0 10,520 Feb 17, 2016 Solution #3 You can buy an anti static wrist strap for under $5. I use it all the time. Plus touching metal for a ground often, not being on carpet which causes friction are all good practice. http://www.amazon.com/BestNow-Static-Eliminator-Elastic-Wristband/dp/B00ZI187I8/ref=sr_1_1?ie=UTF8&qid=1455701696&sr=8-1&keywords=anti+static+wrist+strap+wireless Upvote 0 Downvote Solution
P Paul NZ Polypheme Sep 15, 2014 20,774 3 61,010 Feb 17, 2016 #4 Remember to put the standoffs in. Or you can and will short something Upvote 0 Downvote
