G
Guest
Guest
Archived from groups: alt.sys.pc-clone.dell (More info?)
Hello all,
I have a Precision 670 with the following spec:
Dual Xeon 3.2GHz/800Mhz/1MB
2GB RAM DDR2 400 ECC Dual Channel
Intel E7525 chipset EM64T
128MB PCI-E ATI FIREGL V3100 (ELGA)
80GB SATA HDD 7200rpm
36GB SCSI HDD 10K rpm
16X DVD +/- RW + Soft
16X DVD ROM
Win XP Pro SP2
Problem:
There is only one PCI-32bit slot available and
it happen to be right close beside the PCI-Express
graphic card slot (I would say it is a design
flaw of the main board for this model).
I occupied the PCI-32bit slot with a Wireless
PCI-32bit Zyxel but then have noticed while playing
(hl2) that often after a while the game starts screwing
up the output (textures shown in black and purple blinks
all over the game), seems to me that the graphics card
is getting too hot because of lack of airflow (the
PCI-32bit right on top of it). Would be nice but did not
find around any temp reporting tool for my Dell system, is
there any?
I also tried upgrading the graphic card to XFX GeForce
6600GT and happen exactly the same effect as with the ATI ...
with the GeForce 6600GT I was able to monitor temp and
I was getting ranges of:
- idle: 56C
- peak load: 110C!! this would just burn it in a while ...
Question:
Is there any adapter that I can buy for moving my PCI-32bit
Wireless card into the PCI-X slots? so I can make sure
that the PCI-E graphic card is free and it gets proper
airflow?
Or
Is there any cooling solution for integrating with Dell
motherboards specifically Precision 670 so I can play
safely or even upgrade and overclock the graphics card
without taking away the PCI-32bit card away from the
PCI-E?
TIA,
Best Regards,
Giovanni
Hello all,
16X DVD ROM
Win XP Pro SP2
Problem:
there any?
- idle: 56C
Question:
airflow?
Or
PCI-E?
TIA,
Best Regards,
Giovanni
