Premiere 6.5 Deinterlace problem
J
373
Archived from groups: rec.video.desktop (More info?)
Hi, I captured dv footage in Premiere 6.5 and then exported the movie;
Microsoft avi file. In Export Settings, Special Processing, I selected
Deinterlace. But it has no effect! I still see the image tearing lines
when I play it back. I tried different compressors, no change. In just
won't deinterlace. If I select the Always Deinterlace for a clip on the
timeline though, it does deinterlace that clip. What's happening? TY
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.692 / Virus Database: 453 - Release Date: 28/05/2004
BudMan
39
It would be nice to hear a reply that has some answers or suggestions.
Budman
G
Guest
Guest
This drove me crazy in Premiere 6.0.
After Effects has export settings for Motion Blur, Field Rendering, etc.
called "On for selected layers", which is how I think Premiere is treating
the "Special Processing -> Deinterlace" setting.
In other words, you have to flag every clip in the timeline to "Always
Deinterlace" and also set the "Deinterlace" special processing option. PITA,
I know, but it does the trick.
I also select "No fields" in the video export options. Not sure if that had
an effect on whether or not it would properly deinterlace, but I wasn't
taking any chances.
Oh yeah... use the "interpolate" option for deinterlacing. It usually
produces better results.
Chris
Munged email. To reply by email (each "word" a letter):
see jay bee are oh oh kay ee [AT] em ess en [DOT] see oh em
G
Guest
Guest
"FlyByKnight" <FlyByKnight@example.invalid> wrote in message
news:ID%zc.2379$756.694@fe23.usenetserver.com...
lines
just
the
PITA,
had
> taking any chances.
> Chris
Thanks for the reply Chris. Yeah I've just been using the clip deinterlace,
because nothing else works anyway! This whole matter seems somewhat absurd,
but then the whole program isn't particularly logically designed, so it's to
be expected I guess.
The WMV plugin has a deinterlace option which actually works, so I might
also use that when my project's done. If you have XP, you can also
apparently create full 60 fps progressive video in WMV encoder.
Choosing No Fields just means the resulting video is not interlaced i.e. is
progressive AFAIK. Because you can still have either interlaced
deinterlaced or progressive deinterlaced video :).
Version: 6.0.706 / Virus Database: 462 - Release Date: 14/06/2004
