Premiere Pro & After Effects
Shernel
Commendable
Jan 8, 2017
70
Can I run both of the above mentioned software's on?
G4560 3.50 Ghz
GTX 750 Ti 2gb
DDR4 2400Mhz 8 GB
I would edit videos upto 1080p.
I meet the required screen resolution.
Thanks
What version of Premiere Pro and After Effects do you want to run?
You can find the system requirements for Premiere Pro here from Adobe
On the right side you will see the system requirements for various versions of Premiere Pro.
You can find the system requirements for After Effects here from Adobe
On the right side you will see the system requirements for various versions of After Effects CC.
