Premium fans suggestions should i buy it or should i not
May 23, 2015
8
Hey guys i am gonna build a pc and i wanted to ask a question about premium pc fans. My specs are : CPU; i7 4790k GPU:GTX 980 ti RAM: 16GB DDR3 2tb HDD and a 256 gb ssd. The case i m going to use is fractal design r5. I already got a cpu cooler but for the GPUs and other components is the fan that come with r5 case enough. Do i need a premium fan? I put my pc near a air conditioner and on a wooden table but it is very hot outside. If i should buy a pc fan what do u suggest? Sry for bad english and sry again if i posted this in a wrong section.
I would just try it with the fans that come with it first. If it cools fine then no need for additional fans. So long as they keep it cool and are quiet enough for you keep them. If they're too noisy (which I doubt) or if you need additional cooling then consider adding a fan or two, otherwise you could be wasting money on fans you don't need.
