Prevent sound control panel opening at startup
alecchalmers
Whenever my computer starts up it loads/displays the sound control panel. I cannot find what is causing this, possibly something in startup processes but I've had a look and I can't tell which one.
It's just one of those little annoying things, but any help would be greatly appreciated because I use my laptop for work presentations and ideally I'd like it to look very professional and not be flooded with popups etc.
The only one I think it could be is maybe the Realtek Semiconductor processes, but I was thinking I shouldn't turn these off because they came with the laptop as default software. Trying to research if they actually do anything now.
Here's the ccleaner info:
No HKCU:Run CyberGhost CyberGhost S.R.L. "C:\Program Files\CyberGhost 6\CyberGhost.exe" /autostart /min
Yes HKCU:Run EPLTarget\P0000000000000000 SEIKO EPSON CORPORATION C:\WINDOWS\system32\spool\DRIVERS\x64\3\E_YATIPEE.EXE /EPT "EPLTarget\P0000000000000000" /M "XP-332 335 Series"
Yes HKCU:Run EPLTarget\P0000000000000001 SEIKO EPSON CORPORATION C:\WINDOWS\system32\spool\DRIVERS\x64\3\E_YATIPEE.EXE /EPT "EPLTarget\P0000000000000001" /M "XP-332 335 Series"
No HKCU:Run Steam Valve Corporation "C:\Program Files (x86)\Steam\steam.exe" -silent
Yes HKLM:Run Adobe ARM Adobe Systems Incorporated "C:\Program Files (x86)\Common Files\Adobe\ARM\1.0\AdobeARM.exe"
Yes HKLM:Run Adobe Creative Cloud Adobe Systems Incorporated "C:\Program Files (x86)\Adobe\Adobe Creative Cloud\ACC\Creative Cloud.exe" --showwindow=false --onOSstartup=true
Yes HKLM:Run AdobeAAMUpdater-1.0 Adobe Systems Incorporated "C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\UWA\UpdaterStartupUtility.exe"
No HKLM:Run ADSKAppManager Autodesk, Inc. "C:\Program Files (x86)\Autodesk\Autodesk Desktop App\AutodeskDesktopApp.exe" -tray
Yes HKLM:Run ETDCtrl ELAN Microelectronics Corp. %ProgramFiles%\Elantech\ETDCtrl.exe
Yes HKLM:Run IAStorIcon Intel Corporation "C:\Program Files\Intel\Intel(R) Rapid Storage Technology\IAStorIconLaunch.exe" "C:\Program Files\Intel\Intel(R) Rapid Storage Technology\IAStorIcon.exe" 60
No HKLM:Run iTunesHelper Apple Inc. "C:\Program Files\iTunes\iTunesHelper.exe"
Yes HKLM:Run Launch LCore Logitech Inc. C:\Program Files\Logitech Gaming Software\LCore.exe /minimized
Yes HKLM:Run NvBackend NVIDIA Corporation "C:\Program Files (x86)\NVIDIA Corporation\Update Core\NvBackend.exe"
Yes HKLM:Run RtHDVBg_Dolby Realtek Semiconductor "C:\Program Files\Realtek\Audio\HDA\RAVBg64.exe" /FORPCEE4
Yes HKLM:Run RtHDVCpl Realtek Semiconductor C:\Program Files\Realtek\Audio\HDA\RAVCpl64.exe -s
Yes HKLM:Run ShadowPlay Microsoft Corporation "C:\WINDOWS\system32\rundll32.exe" C:\WINDOWS\system32\nvspcap64.dll,ShadowPlayOnSystemStart
Yes HKLM:Run WindowsDefender "%ProgramFiles%\Windows Defender\MSASCuiL.exe"
Yes Startup Common GBOSDV3.lnk GIGABYTE TECHNOLOGY CO., LTD. C:\Program Files\GIGABYTE\SmartManagerV3\OSD\GBOSDV2.exe
Yes Startup Common SystemTray.lnk C:\Program Files\GIGABYTE\SmartManagerV3\SystemTray.exe
Yes Startup Common Welcome.lnk C:\Program Files\GIGABYTE\Smart USB Backup\Welcome.exe
No Startup User EvernoteClipper.lnk Evernote Corp., 305 Walnut Street, Redwood City, CA 94063 C:\Program Files (x86)\Evernote\Evernote\EvernoteClipper.exe
Yes Startup User EvernoteTray.lnk Evernote Corp., 305 Walnut Street, Redwood City, CA 94063 C:\Program Files (x86)\Evernote\Evernote\EvernoteTray.exe
No Startup User LAN Optimizer.lnk Realtek Semiconductor C:\Program Files (x86)\Realtek\LanOptimizer\LanOptimizer.exe
Yes Startup User Logitech Gaming Software 8.83.lnk Logitech Inc. C:\Program Files\Logitech Gaming Software\LCore.exe
