Primary display issues PC
Aug 7, 2018
So I have 2 monitors in my setup and my main on is plugged into my 1070ti via HDMI and my second smaller and worse monitor is plugged into motherboard via VGA. I have tried to turn on the integrated graphics to get my second monitor to work and it does but it takes precedence over my primary monitor when booting and has all the desktop apps on it. I turn the graphics off and my second monitor won’t display anything. Is there an easy fix I’m not finding?
Just get a Display Port to VGA adaptor for your second monitor and plug it into the GPU. You can't use both the gpu and mobo inputs at the same time for multi displays.
