I recently moved my older HD Tv (an LG Plasma) downstairs next to my computer for better movie viewing from the computer, but I noticed an odd problem when I plugged it in.
My monitor, which has always been used on this PC (attached via DVI) got sent to the Number 2 identity and the TV became Number 1. Now this is not such a big deal, except that it causes for some weirdness every once in a while. Some times programs automatically open on the TV (even though the monitor is definitely set as the Main Display).
Also, when I wake the computer up from hibernation sometimes, the monitor display does not turn on and I cannot see anything until I turn on the TV and switch displays (even though the pc booted down with only the monitor on).
Lastly, when I do Windows + P and change the screen projection and I select PC Screen Only, it leaves only the TV on, which should not be correct.
I will state again, my monitor IS set to be the main display. I have heard that you cannot change the numbers associated with the displays (thanks a lot Microsoft), but one would think that making a particular screen your primary would override all of these things.
Any ideas or suggestions, it's just getting a little frustrating to fiddle with all of the time.
