Archived from groups: microsoft.public.win2000.dns (
More info?)
In news:uBOTtf8hFHA.2152@TK2MSFTNGP14.phx.gbl,
php <php> posted this:
> Hello. Recently, I am studying about DNS. I have some question on the
> Primary DNS suffix and connection Suffix. If I have set my Primay DNS
> suffix(System --> Computer Name) and in NIC set connection suffix.
> Also select "register this connection to DNS", which one will be use
> in DNS registration?
If you have Register this connection's addresses in DNS selected in TCP/IP
the Primary DNS suffix will be used, if you have "Use theis connection's DNS
suffix in DNS registration" selected, and that zone supports DDNS both the
Primary and connection DNS suffix will be used in DNS registration.
> Actually, I have done some test. Connection Suffix will override the
> primary DNS on Client. But in DNS server, Primary DNS suffix will
> override it. But still quite confuse about it. THanks.
Actually neither will override the other, the machine will attempt
registration using both domain names, if they are different.
DCs use a different mechanizm because on a DC there are two types of DNS
registrations going on. Netlogon registrations can only be disabled in the
Registry, TCP/IP registrations use a combination of both registry and GUI
settings (actually all are in the registry but some of the registry settings
are controlled by the GUI. For a DC to register its records, the Primary DNS
suffix must be a correct match of the AD domain name and forward lookup
zone.
What registrations should take place depend on the role of the server, if
the server is a DC most registrations can only be modified using the
registry. Clients use the GUI settings, which in effect control the
registry. If the client is a member of a domain, these settings can be
controlled by a GPO, which override the client settings.
246804 - How to Enable/Disable DNS updates in Windows 2000 and in Windows
Server 2003
http://support.microsoft.com/default.aspx?scid=kb;EN-US;246804&sd=RMVP
How to configure TCP/IP to use DNS in Windows XP:
http://support.microsoft.com/default.aspx?scid=kb;en-us;305553
Best regards,
Kevin D4 Dad Goodknecht Sr. [MVP]
Hope This Helps
When responding to posts, please "Reply to Group"
via your newsreader so that others may learn and
benefit from your issue, to respond directly to
me remove the nospam. from my email address.
http://www.lonestaramerica.com/
Use Outlook Express?... Get OE_Quotefix:
It will strip signature out and more
http://home.in.tum.de/~jain/software/oe-quotefix/
Keep a back up of your OE settings and folders
with OEBackup:
http://www.oehelp.com/OEBackup/Default.aspx
