G
Guest
Guest
Archived from groups: comp.sys.ibm.pc.hardware.storage (More info?)
My computer has suddenly started reporting the error message "Primary
IDE channel no 80 conductor cable installed" after the BIOS has
detected the harddrives connected to my system.
I have the following configuration:
Primary Master: West Digital 80GB ATA100
Primary Slave: DVD Writer
Secondary Master: Seagate 180GB ATA100
Secondary Slave: DVD ROM
The system boots using the following:
Primary Master: UDMA33
Primary Slave: UDMA33
Secondary Master: UDMA100
Secondary Slave: UDMA33
I have tried disconnecting the DVD Writer on the Primary Slave, but
that makes no difference. I have tried a brand new 80 pin cable for the
Primary channel, but that makes no difference. I have tried putting the
Western Digital HD on the known working secondary Master connection,
Could this be a problem with the hard disk itself? The harddisk runs
perfectly ok and reports no SMART errors or anything like that, but
just runs slower than it could.
Thanks,
Matt
Remove SPAM trap if replying by email.
Thanks,
Matt
