Primary internal battery
Robert36
Commendable
Dec 9, 2016
14
I keep getting 'primary internal battery' is running low error 601, every time i log in. I thought this was the coin sized silver battery you find when you take panel from bottom off. I replaced it with new battery, still happening. Also laptop is running slow and freezing, videos unwatchable due to buffering and sticking. Is it maybe the big remote control sized battery that needs replaced?
Hmm, something could still be wrong with the laptops actual battery then. Unless maybe the coin battery isn't "in all the way"
Can you run the laptop without it's main battery attached to see if the error still comes up?
It should. You may have to set the time again, but if you set the time correctly, restart/unplug the computer, and check the time and it's wrong, the battery is still a problem.
Yes. The time has gone wrong again. This is a brand new silver battery, but still the primary internal battery message 601, telling me battery is low, appears, time still goes wrong, and its slow, freezing, switching itself off.
Hi. it won't start when the big battery is removed. I've replaced the small coin battery twice, even secured it with tape, still getting primary internal battery message, still slow and switching itself off. The problem is, i'm receiving that message, but I've done what I can to prevent it. Thanks for your help.
hmm, i'd replace the big battery then.
I think you're right. Just noticed on the hp site, a comment from someone saying they'r replaced silver battery but still got the 601 error message., to which someone else replied ''This is a slightly misleading error as it does in fact refer to your notebooks main battery, not the cmos cell.'' I'll buy a new main battery, and fingers crossed. Thanks for your help.
