rojito
I don't believe any air cooling solution would let you get 3,6 GHz at 60º. When you are over 3 GHz on a Q6600 Heat starts to increase exponentially.
Your previous cooler wouldn't have been able to take you to a stable 3,4 GHZ, remember you where testing it with much lower voltages (which is why it was unstable).
I believe you should be very happy, you got to reach your goal of 3,6 GHz plus you made it without reaching 70º, that's amazing considering your CPU and that you're on air.
By the way, never use more voltage than the minimum needed by your hardware (at your desired setting), if you increase them, you will be just creating more heat and shortening the life of the component.
