I recently upgraded my CPU cooling to a CM Nepton 240m. After installation I booted up my PC and ran a stress test using Prime95 for about ten minutes. During the stress test all my temps seemed fine (CPU was at 41 °C). Then all of a sudden my PC shut off. I smelled something burning at that time. I waited about 15 minutes and wasn't able to turn my PC back on.
I tested my PSU with a paperclip and it seemed fine. I figured since my CPU wasn't running too hot and wasn't overclocked it was probably my motherboard. So I replaced my motherboard with a new Crosshair V Formula-Z. After setting everything up and going through the No POST checklist and all I got was lights on the motherboard. No case fans. No PSU fans.
I tried reseating the RAM and unplugging HDD and still got nothing. At this point I checked the CPU and it seemed like I put too much thermal paste on it as it was spilling over onto the motherboard. So I cleaned that all up, checked the CPU for bent pins, reseated everything...
This time the PC started up (fans and everything) but no video. So I shut it down, plugged in my monitors. Tried to start it up again and this time NOTHING. No case fans, no beeps, just a light on the motherboard was green.
I checked for something that might be shorting the motherboard and there was nothing.
I'm not sure what to do next. Is it the CPU? Please help this is driving me crazy!
Thanks!
Thanks!
