K Kayinmoon Honorable Dec 3, 2013 47 0 10,530 Jan 3, 2014 #1 I was wondering if Blend testing was ok for seeing what my max load temp would be under worst case scenario. And if not, then which one should i use?
Solution CepheiA Jan 3, 2014 Small FFT's. Small FFT's mainly stress the CPU, Large FFT's mainly the Ram, and the blend is a little of everything.
CepheiA Honorable Aug 31, 2013 211 0 10,760 Jan 3, 2014 Solution #2 Small FFT's. Small FFT's mainly stress the CPU, Large FFT's mainly the Ram, and the blend is a little of everything. Upvote 0 Downvote Solution
P Pinhedd Champion Aug 7, 2007 10,342 20 56,965 Jan 3, 2014 #3 Kayinmoon : I was wondering if Blend testing was ok for seeing what my max load temp would be under worst case scenario. And if not, then which one should i use? If you want to test for thermal safety don't use Prime95, use Intel Burn Test Upvote 0 Downvote
