G
Guest
Guest
Archived from groups: comp.periphs.printers (More info?)
Currently networked through an 8-port switch:
3 Windows 98 SE PCs
1 Windows XP laptop
Intel Netport Express Print Server with 2 parallel port printers attached
Just added a wireless NIC and 4-port wireless router to use with the
laptop. Connected the wireless router to the switch with a crossover
cable. Access to the other computers is fine. So is access to the
internet. The problem is that printing from the laptop when it is
connected to the network wirelessly hangs. There doesn't seem to be any
way to fix that.
So, I've been looking at buying a wireless print server. From the Belkin
Wireless Print Server F1UP0001 manual:
"This [ethernet] port [on the print server] is used to connect the PC to an
ethernet network via CAT5 cable. Note: Using this port will automatically
disable wireless functionality in the Print Server."
Is there a print server that can handle both wired and wireless connections
or does one need separate print servers and printers -- one set for the
wired PCs on the network and and another set for the wireless?
Thanks.
3 Windows 98 SE PCs
1 Windows XP laptop
way to fix that.
Thanks.
