printer port redirection problems
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
Archived from groups: microsoft.public.win2000.termserv.clients,microsoft.public.windowsnt.terminalserver.client (More info?)
I have a TS server 2000 and 3 remote office that connect through it, 4 TS
users total. One client is giving me difficulty with her printer. First, it
wouldn't connect like the others (<clients or server printer>/<client host
name>/Session <session #>). I managed to connect it manually and redirect it
to her TSxxx PRN0 port, and get it to work that way. The printer would still
look like it's local, but it worked. But often, I had to connect to the TS
server, and reassign the right TSxxx PRN port, or get the printer online (it
would go offline by itself). Now, it seems like it's connecting just fine,
but often, it will set on TSxxx PRN1 instead of PRN0. Whenever it does that,
it won't print. She have to go and manually set it to PRN0. It's not a major
issue when I'm around, but I have other obligations and am not always
available to get her to print back, plus she's going on vacation next week
and her replacement doesn't know all that stuff.
Her station is a Win2k station, up-to-date. The printer is an HP Laserjet
1200, connected by a share (\\secretgs\hp I think) on a Windows 98 station.
I tried a TON of different drivers, be it PS, PCL5e, PCL6, whatever. Now
it's using the PS driver on both the server and workstation, and I have
deleted the other useless drivers from the Server Properties applet. I know
there are some kind of driver name restriction when using Win2k and Win98,
but the driver names are the same on both 2000 machines. I also use a
mapping (net use lpt1 \\secretgs\hp /persistent:yes) so that the server
redirect the printer to LPT1. Anyway, I'd greatly appreciate help, as I have
already spent a LOT of time googling for a fix.
Make this registry addition on the user's win2k
station, with her logged on to her workstation:
http://support.microsoft.com/kb/302361
And
Use one of the newer Remote Desktop
Client versions:
5.1.2600
5.1.2600.2180
5.2.3790.0
5.2.3790.1830
No need for the net use trick anymore.
I have used the PCL6 & PCL 5e 1200 drivers with
success As far as the printer going offline, not sure
what is happening there, maybe a communication
problem between the win2k and win98 machines.
Thanks.
-TP
> 4 TS users total. One client is giving me difficulty with her
> printer. First, it wouldn't connect like the others (<clients or
> server printer>/<client host name>/Session <session #>). I managed to
> connect it manually and redirect it to her TSxxx PRN0 port, and get
> it to work that way. The printer would still look like it's local,
> but it worked. But often, I had to connect to the TS server, and
> fine, but often, it will set on TSxxx PRN1 instead of PRN0. Whenever
> it does that, it won't print. She have to go and manually set it to
> PRN0. It's not a major issue when I'm around, but I have other
> obligations and am not always available to get her to print back,
> plus she's going on vacation next week and her replacement doesn't
> Laserjet 1200, connected by a share (\\secretgs\hp I think) on a
> Windows 98 station. I tried a TON of different drivers, be it PS,
> PCL5e, PCL6, whatever. Now it's using the PS driver on both the
> server and workstation, and I have deleted the other useless drivers
> from the Server Properties applet. I know there are some kind of
> driver name restriction when using Win2k and Win98, but the driver
> names are the same on both 2000 machines. I also use a mapping (net
> use lpt1 \\secretgs\hp /persistent:yes) so that the server redirect
Thanks for the tips. I will not have any chance to test it before Tuesday or
Wednesday next week, so if anything else, I'll repost.
"TP" <tperson.knowspamn@mailandnews.com> wrote in message
news:OpQ$u6FXFHA.712@TK2MSFTNGP14.phx.gbl...
> Make this registry addition on the user's win2k station, with her logged
> And
> Client versions:
> 5.1.2600
> 5.1.2600.2180
> 5.2.3790.0
> 5.2.3790.1830
> I have used the PCL6 & PCL 5e 1200 drivers with success As far as the
> printer going offline, not sure what is happening there, maybe a
> communication problem between the win2k and win98 machines.
> Thanks.
> -TP
>> know all that stuff. Her station is a Win2k station, up-to-date. The
>> printer is an HP
