printer problem event 61
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
Archived from groups: microsoft.public.windowsnt.terminalserver.applications (More info?)
Hi group
I always use the HP 9300 printer over TS. But, now only the administrators
can print in this .. other users i received the error event log 61 ..access
denied. I try install the driver again .. but nothing!! This same problem
happen with epson c42. I had install Thinprint for tests .. after this the
problem happened .. but I unistall the thin print .. and the printers above
not work. All the others print that I have works.
Please .. help me!!
I will delete all the call for this print in the register .. but, the
problem continue .. I don´t know what to do!!
please .. somebody knows this problem??
"Janaina" <jrodrigues@sattours.com.br> escreveu na mensagem
news:ut66NwWzEHA.1396@tk2msftngp13.phx.gbl...
> Hi group
administrators
...access
the
above
Since your users get an "acces denied" error code on Event 61, and
it works for Administrators, you have a permission problem.
As with all permission problems. I would download FileMon and
RegMon from http://www.sysinternals.com/. Run them as
administrator, start a TS session as a normal user and try to
print.
FileMon and RegMon will show you all "access denied" errors
that occur, so that you can give your users the necessary
permissions on a file-to file or Registry subkey basis.
Vera Noest
MCSE, CCEA, Microsoft MVP - Terminal Server
http://hem.fyristorg.com/vera/IT
--- please respond in newsgroup, NOT by private email ---
"Janaina" <jrodrigues@sattours.com.br> wrote on 19 nov 2004 in
microsoft.public.windowsnt.terminalserver.applications:
> Please .. help me!!
> but, the problem continue .. I don´t know what to do!!
>> Hi group
> administrators
>> 61
> ..access
>> same problem happen with epson c42. I had install Thinprint
> the
>> printers
> above
Latest posts
