Archived from groups: microsoft.public.windowsnt.terminalserver.misc (
More info?)
Hi
it's on a win2k SP4 box not applied any hot fixes
the print devices we use are HP, as for drivers loaded
they are HP's. I'll proabbly try removing the drivers at
the weekend and use on native win2k drivers.
thanks for all your help.
Cheers, Mark
>-----Original Message-----
>Did you install the pre-SP5 hotfix for Event 61,
mentioned on
>TechNet? There might be un underlying error which is
overwritten.
>Which printer type is this about? Did you install any 3th
party
>printer drivers? If so, I would uninstall them and use
native
>drivers only.
>Vera Noest
>MCSE,CCEA, Microsoft MVP - Terminal Server
>http://hem.fyristorg.com/vera/IT
>*----------- Please reply in newsgroup -------------*
>"Mark" <anonymous@discussions.microsoft.com> wrote in
>news:28ba401c464bf$28d47580$a501280a@phx.gbl:
>> Hi
>> thanks for the info
>> Yup, tried that. The server isn't running low on any
>> resource, it seems fine just stops users from printing
>> after being logged on for awhile.
>> it's driving me mad
>> Cheers, Mark
>>>Since you get error code 3003, don't bother with error
>> codes 63,
>>>129, 29 or others. They don't apply to you.
>>>Have you follow the link on the same page to Microsofts
>>>information about EventID 61? It includes a number of
KB
>> articles
>>>(some specific for TS) that might describe your
situation.
>>>http://www.microsoft.com/technet/support/ee/result.aspx?
>>>EvtSrc=Print&EvtID=61&ProdName=Windows+Operating+System&
LC
>> ID=1033
>>>&ProdVer=5.2
>>>Vera Noest
>>>MCSE, CCEA, Microsoft MVP - Terminal Server
>>> --- please respond in newsgroup, NOT by private email -
>>>news:27a0b01c4642f$03bac9b0$a601280a@phx.gbl:
>>>> also found this
>>>> 3003 A StartDocPrinter call was not issued (printer
not
>>>> reached on =
>>>> network)
>>>> 63 Your file waiting to be printed was deleted
(user
>>>> deleted job)
>>>> 129 The %1 application cannot be run in Win32 mode
>>>> 29 The system cannot write to the specified device
>> (port
>>>> error)
>>>> 3003 and 63 should not trouble you, as these occur in
>>>> quite normal
>>>> situations.
>>>> 3003 is normal?? well it's not noraml when the users
>>>> can't print? ;-)
>>>> Mark
>>>>>Hi Vera
>>>>>already been onto this site and nothing there of any
>>>> help :
>>>>>( I did somewhere else it could be, like network
>> drives,
>>>>>that after 15 minutes of inactivity the connection is
>>>>>dropped ala red cross on network drives.
>>>>>If it this which machine do I apply the reg hack to?
>> the
>>>>>client or the server?
>>>>>Thanks again for any ideas
>>>>>Mark
>>>>>>net helpmsg 3003 translates this error to:
>>>>>>"A StartDocPrinter call was not issued" (meaning:
>>>> printer
>>>>>was not
>>>>>>reached on network).
>>>>>>Check if the tips here help you find the cause:
>>>>>>http://www.eventid.net/display.asp?
>> eventid=61&eventno=47
>>>>>>&source=Print&phase=1
>>>>>>Vera Noest
in
>>>>>>news:2805101c4640e$afc883d0$a401280a@phx.gbl:
>>>>>>> Hi
>>>>>>> I have a win2k SP4 machine running TS. Every so
>> often
>>>>>>> users complain they can not print to networked
>>>>>printers,
>>>>>>> but if they logoff and then back on again they can
>>>>>print.
>>>>>>> Is this something to do with the printer ports
>> timing
>>>>>out?
>>>>>>> Source: Print
>>>>>>> EventID: 61
>>>>>>> The document Microsoft Word - Document1 owned by
>> OWNER
>>>>>>> failed to print. Win32 error code returned by the
>>>> print
>>>>>>> processor: 3003 (0xbbb).
>>>>>>> anybody any ideas?
>>>>>>> TIA, Mark
