Printer problem
If you mean you have a system that only has a parallel printer port, then no, you cannot get an adapter to connect a USP printer to the port.
If you mean you have a system that only runs DOS, has USB ports, and you want to connect a USB printer, then yes, you can get a DOS driver to do that.
If you mean something else, then please provide more details.
It's a Bricon Club master for entering racing pigeon information and has to be printed through the master from the individual timer/clock
This is from the manual as I'm not sure what it means "A printer is necessary to print the basketing and clocking lists. You can use any DOS-compatible printer (with a language of PCL5 or 6) but please note that windows/USB printers are not compatible. Use a standard parallel printer cable to connect printer to the bricon club master."
If you wish to look at it you maybe able to view it from website www.bricon.be
Thanks
