Hi all
Im hoping someone out there will be able to shed some light on my printer problem.
I start my PC and start a print job and it prints off with no problem at all, once done though the job stays in the queue on "deleting". I have cancelled the job and restarted the spooler which does remove the "deleting" job, but even when i try another print job it will not print, this time it is stuck in the queue on "printing"
I have been into the system32 folder and removed any items i found in the spool folder (which i was told could cause a problem)
I am running Comodo and read that the Firewall could be causing the problem, so i went into the setting found any Lexmark entry and gave access, i also worked with it disabled but to no avail the problem still occured. I even gave all lexmark entries in Windows firewall access to, problem stayed.
I have even been into the Control Panel and removed the setting which made my PC put the printer in sleep (read that could cause a problem) Problem stayed.
So far everything i have read i have tried but each time i print the above problem occurs.
Now if i reboot the PC with a stuck job in the queue, when its reboots it starts to print the job that was there, but no more than that. If i remove all jobs from the queue reboot and try a fresh print job, that works but no more after.
So at the moment if i want to print alot of work i have to print, remove queue, reboot, print, remove queue, reboot and print, so on so forth. As you can imagine this is a pain in the ass to do.
I am running on a
Intel i5 750,
Asus P7P55-M Motherboard
2x2GB Ram
Windows 7
The Printer in question is a Lexmark X1180 with the Windows 7 (or compatible) drivers installed.
Thanks in advance
I am running on a
Intel i5 750,
2x2GB Ram
Windows 7
Thanks in advance
