Printing problem : port DOT4_001
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.print_fax (More info?)
Hi all,
I'm having the following problem with my printer: the first time I start it,
I can print and fax without a problem. If I switch the printer off, for any
reason, then switch it on again, I can't print anymore or fax, or whatever.
As the troubleshooter said, I went to see which port is used for my printer
and I found it installed on the port DOT4_001. Is this normal? Could this be
the source of the problem?
TY
If the printer is connected thru a USB port then using the DOT port
is incorrect. Reinstall it using manufactureers instructions. Do not
connect the printer to the PC untill unstructed to do so.
Uninstall & reinstall Printer
http://www.coribright.com/windows/Article%20One.htm
XP-WNP
Today is the first day of the
rest of your life.
"duxxyy" wrote:
> Hi all,
> TY
not necessarily. DOT4 is supported over USB for many of the HP
multifunction devices
Alan Morris
Windows Printing Team
Search the Microsoft Knowledge Base here:
;kbhowto]http://support.microsoft.com/default.aspx?scid=fh;[ln];kbhowto
"Byte" <Byte@discussions.microsoft.com> wrote in message
news:09D06D23-A25A-4579-9A6A-E6010214CE1E@microsoft.com...
> XP-WNP
> rest of your life.
> "duxxyy" wrote:
> > Hi all,
it,
any
whatever.
printer
this be
> > TY
