Question prob. msi afterburner on crack (3000mhz not 2000)
Apr 16, 2019
31
I've had my 2 3000mhz 8gb trident z rgb sticks for a while now, and i just now noticed that it displays my rame at 2000 and not 3000mhz.As anybody (hopefully) would do i checked the bios and saw that it was indeed 3000mhz ram.Same on the box, so can someone help me fix afterburner it triggers me a lot!
Try cpuz it's more accurate. Memory tab > dram frequency.
If it says 1500 (not accounting for ddr so times 1500 by 2) all is good and ignore Msi Afterburner and hopefully it gets an update. Nothing more you can do with Afterburner.
