Problem Adding a PCI-E Card to Dell Dimension 4700
G
Guest
Guest
Archived from groups: alt.sys.pc-clone.dell (More info?)
I tried adding a MSI NVIDIA 6600 GT card to my new Dell Dimension 4700.
The card worked for about a day... and for about 10 minutes of
Half-life 2. Then the computer just turned off, and would not boot
again with the card inserted. I've tried different power supplies, but
nothing seems to resolve the issue. Any ideas???
G
Guest
Guest
I have-- I don't believe this to be a software issues. The computer
will not post, or boot at all with the card inserted in the PCI-E slot.
G
Guest
Guest
isuheineken,
Have you gone to NVIDIA or the card's manufacture site and see if there any
video driver upgrades?
http://www.nvidia.com/object/winxp_2k_66.93
Have you installed DirectX 9.0c Redistributable from Microsoft?
http://www.microsoft.com/downloads/details.aspx?displaylang=en&FamilyID=9226a611-62fe-4f61-aba1-914185249413
Rich/rerat
(RRR News) <message rule>
<<Previous Text Snipped to Save Bandwidth When Appropriate>>
"isuheineken" <kealhofer@gmail.com> wrote in message
news:1109139792.592567.248800@f14g2000cwb.googlegroups.com...
G
Guest
Guest
isuheineken,
You did not say if you had disabled the onboard video adapter, or if you got
the card from Dell, installed on your PC at the time of purchase. If you got
the card from Dell it could be defective. If so, call customer support and
they should send you another one. If you bought card from a computer store.
You may need to return card for replacement, at a minimum, see if they can
test it, to see if it is defective.
Have you tried the following:
1. Reboot PC in SafeMode> Control Panel> Hardware tab> Device Manager>
Display Adapter> Click on onboard adapter name> Properties> Device
Usage-Disable Device.
2. Shutdown PC> Reinstall card, making sure that you place the card in the
right slot. Make sure you have the video driver CD handy.
3. Restart PC> Use CD to reinstall drivers.
Add MS to your News Reader: news://msnews.microsoft.com
Rich/rerat
news:1109144736.722075.241500@f14g2000cwb.googlegroups.com...
