That speaks to IRST (Intel Rapid Storage Technology) being installed.Hi,
After I installed new os, and I reset my bios as default, don't know why but before the os loads, i see that screen.
Idea?
Thanks.
Pic
Yep but I don't know how to disable itThat speaks to IRST (Intel Rapid Storage Technology) being installed.
Not needed if you are not doing any RAID thing.
I'm not sure there is any "uninstall", other than starting over with a clean install.Yep but I don't know how to disable it
I made a clean install.I'm not sure there is any "uninstall", other than starting over with a clean install.
When did you install this OS?
yes it is but it is not optimal, before that it was not there..Does it actually work and the screen just shows up for a few seconds? If it's working fine aside from the screen, just let it be.
I have found over many years that a small inconvenience, if even that, is not worth the trouble fixing it and possibly breaking something else. It boots and works, what if you make a change that makes it not boot anymore?yes it is but it is not optimal, before that it was not there..
