problem - autoexec.nt
vinoth
Archived from groups: microsoft.public.windowsxp.customize (More info?)
I tried installing a new software when i run setup.exe this is the message i
get
Header-------> 16 bit windows Subsystem
C:\WINDOWS\SYSTEM32\AUTOEXEC.NT. The system file is not suitable for running
MS-DOS and Microsoft windows applications. Choose 'close' to terminate the
application.
I am using winxp pro sp2
Hi
Please see if the following article helps:
"Error Message When You Install or Start an MS-DOS or 16-Bit Windows Based
Program"
http://support.microsoft.com/?kbid=324767
Will Denny
MVP - Windows Shell/User
Please reply to the News Groups
"Vinoth" <svchordia@hotmail.com> wrote in message
news:OVTcuMTtEHA.3152@TK2MSFTNGP14.phx.gbl...
>i get
> running MS-DOS and Microsoft windows applications. Choose 'close' to
> terminate the application.
> get
> application.
Hi
Error message when you install or start an MS-DOS or 16-bit
Windows-based program
http://support.microsoft.com/default.aspx?scid=kb;en-us;324767
You can put back the standard version of autoexec.nt/config.nt by
copying a backup copy held in %windir%\repair\ to %windir%\system32\
(%windir% is typically C:\Windows) instead of using the procedure in
the KB article above.
Could be caused a trojan or something similar, e.g.
TrojanDownloader.Win32.Dia.a, more about this here:
http://groups.google.com/groups?selm=5f6f139.0409140618.749324fe%40posting.google.com
Also, AVAST (antivirus software) can be the cause if you
have WinXP SP2 installed:
http://groups.google.com/groups?threadm=8PCdnSzBqtmadsPcRVn-gQ%40comcast.com
torgeir, Microsoft MVP Scripting and WMI, Porsgrunn Norway
Administration scripting examples and an ONLINE version of
the 1328 page Scripting Guide:
http://www.microsoft.com/technet/scriptcenter/default.mspx
