Hi guys,
I have a modem (Technicolor TG582n) that doesn't allow to block ips via a browser interface.
I have tried doing the task via telnet following this guide: http://phil.tinsleyviaduct.com/tg582nfirewall.html
:expr add name=blockedips type=ip addr=xxx.xxx.xx.xxx
:firewall rule add chain=forward_level_Normal index=2 srcintf=wan srcip=blockedips action=drop
In the past I have managed to complete the task following the guide but when the modem has to be reset I need to rewrite the rules.
The problem I am facing is that I cannot complete the command since I get this error:
Error: Unknown error.
Bad value for parameter 'chain forward_level_Normal'
Through the command ":expr list" I can see the blocked addresses but not the firewall rule.
I don't know what I am doing wrong so i hope someone could provide some help.
Many thanks.
Many thanks.
