Hello, i have some question here. i have surfed all over the forum and couldn't find the solution for this.
Motherboard : Gigabyte P67-DS3-B3 (Socket 1155) rev 1.0 (which support 2133mhz RAM as i saw on their website for this motherboard type)
RAM : Corsair Vengeance Pro (2x8GB) PC17000 (2133mhz)
i try to manually change the frequency on the BIOS from 1333mhz to 2133mhz and when i "Safe and exit" the computer always fails to boot and there is a message :
"The system has experienced boot failures because of overclocking or changes in voltage. Last settings in BIOS setup my not coincide with H/W states."
and i tried to change it to 1600mhz, it works fine.
i need an advice on How do i change it to 2133mhz, because according to the specs, my motherboard and RAM supported to do so.
Thanks.
Jason
Thanks.
Jason
